Old 03-30-2016, 11:56 AM   #4
911monty
911monty's Avatar
Originally Posted by PorscheFan5 View Post
Yes! Thanks 911monty!
Are the Porsche cables (wires) 1/8" (the bore in this item is 5/32" or 4mm that will be swaged) dia...? Just wanted to confirm. Also are these standard automotive size (dia) used by most cars?
I don't have my cables exposed to measure, If needed I can. I just sent an example of the type end that off the cuff should work. You will need to measure and compare to the specifications to determine which to use. Make sure there is sufficient clearance of the end when in the release position. You may also check in your area for an aircraft hardware store so you can select the proper connector. They would probably swage the fitting on for you! Here is a link to various sizes.
Search results for: 'Aircraft Eye End' | APS
