Old 03-30-2016, 03:31 AM   #10
RoughDobermann
Originally Posted by jcslocum View Post
You cannot trust what the dealer says!! If they do not have paperwork then it didn't happen. Did the PPI include a compression test and a leak down test?
What was the code for the CEL?
$1800 seems fair if they put an $800 bearing in. Lots of labor there and there will be some things found once they get into it. Clutch, CV joint, Slave Cyl, rear shocks, etc....
You need more info and we need some pics too!!!
I don't know if they performed those tests. I will check, thanks.
I don't have the CEL code. The dealer says it was inactive 02 sensor codes.
RoughDobermann is offline   Reply With Quote
