Old 03-30-2016, 03:56 AM   #1
RoughDobermann
I had the PPI done. Here's what they found:
Rear main seal seeping.
2. Shift linkage not secured.
3. Mud flaps on all 4 corners damaged/missing.
4. Front sway bar end links torn.
5. Under paneling damaged.
6. Rear badge broken
7. Center glove compartment not latching
8. Left front fender painted 10-11.5microns (factory 4.5-6microns)
9. Left headlight replaced
10. Blinker switch not operating properly
11. Park brake adjustment
12. Broken right front side marker light
13. Gas cap seal cracked
14. Front trunk light inop
15. Battery cover securing nut broken
16. Oil over filled- Recommend oil change
17. Due for brake fluid service
18. Abnormal tire wear- recommend alignment
They also couldn't confirm that the IMS bearing has been replaced. It seems like the RMS seal is the biggest issue.
Thoughts or comments would be welcomed! Thanks!
RoughDobermann is offline   Reply With Quote
