Second the comment to check the foam trays for holes. Check well. Look all the up under the metal bracket that it may be jammed under. You can also unbolt the tod from the other end. Then slide the entire rod out. I would recommend taking both rods ought. You will need to compare them to ensure that neither one has bent.
