Quick update:
I found 12v Sw right where I need it!
In the center console area there is a unused 4 pin connector, that I think is for the phone option. This connector has both 12vBatt and 12vSw. The RD/GRN wire is 12vBatt (continuous) and GRN/BLK is 12vSw (Switched). Checked it with the DVM, and confirmed.
Now I can just wire from right there....
Talking about the fuse, I can put an inline fuse from this to the junction block I created. Question is what size fuse should I use? The loads are:
- PS pump from MR2 Spyder
- Andromeda display for my EV (just a LCD display)
- Homelink remote for garage door
- May run the GAST vaccum pump from the same place for brakes...
I should probably find out the current consumption of the above and add them up and put a fuse at 150% or 200%...what do you guys think?
