Old 03-28-2016, 10:28 AM   #22
The Radium King
The Radium King's Avatar
my lowering was relatively substantial - 1.5" all around iirc - and I did start to feel some bump steer as a result - made much worse with new rear tires however - fixed with some adjustable front toe links.
and I pulled my alignment info and reread - rear shock top mounts are three settings and I am getting -1.5 in the middle setting with adjustable rear toe links. front top mounts are slotted and I am getting -2.25 with standard control arms. with gt3 lcas the sky should be the limit for you.
