Originally Posted by geraintthomas
Right okay. Could you give more information about this release valve, where it can be found and what I'd have to do to replace it if it's bad?
Ahh. Pull the oil cap and coolant tank caps off. Then pull the flat plastic trim plate off, May need a flat screwdriver to help lift one corner. Underneath that cover is a wire bail that you lift to release air in the system when filling the coolant system. Search filling the cooling system for more info. Will need to be done with the loss of coolant in reservoir.
