So I did a second Distilled water flush. I was hoping 1 water then 50/50 but the drained water was still pretty green. This time I dropped the nose on the ground with the rear on ramps and refilled. I then ran at idle and 20 min, up to 170s, then a drive with purge open. Everything ran cool, much cooler than before.
So even with the UView Airlift, it appears that car level is important. If not nose down at least level. I don't know if the purge was over kill or not.
So tonight I hope to drain last time and fill with 50/50 pink and be done.
It will be interesting to see how cool it runs on the hwy. Since using the Torque App, it just ran a steady 194 F.
Saturday it took me 20+ mins of stop and go(after 20 min idle in the driveway) to finally get to 190s
Seal Grey
