"Please advice on what to expect before I had it towed to the closest dealer."
I hope that you didnt crack the engine's head by driving the car with low coolant. Remember, ALL newer cars usually have Aluminum engines. Aluminum engines can easily crack with erratic high temps(low coolant). A fairly simple Cooling system (Radiator, Reservoir, hoses, thermostat, water pump...) problem MIGHT have escalated to a major engine disaster...OUCH $$$....
Whatever happens, have the mechanic do a compression check on all cylinders
GoodLuck!
