Old 06-11-2006, 04:29 PM   #1
lejolierogue
Please Help! Radiator Leak Affecting Pwr Steering!!!
Dear enthusiasts:
My 99 Boxster had a radiator leak last Friday that drained all the way. So, I filled it up with tap water just to make it home from work. About 20 minutes of driving, I notice the temp rising beyong 180. Then the light on the temp meter started blinking followed by the ABS and Battery light coming on. Finally, my steering 'hardened' as if the power steering died.
Stopped the car to find all the water drained from the radiator. Do bear in mind that the temp was 3/4 ways to the max. Finally bought some coolant and radiator sealant and drove home. On reaching home, I had fumes comig out of both vents. I guess from the coolant dripping on the engine.
Left it for a day but the ABS and battery light is still on and steering had no improvements. Tried to disconnect the battery to no avail.
Please advice on what to expect before I had it towed to the closest dealer.
Thanks in advance.
le jolie rogue
lejolierogue is offline   Reply With Quote
