Old 03-24-2016, 11:31 PM   #1
fahmasan
Went through four batteries before I read on here about the horn ring rubber grommets going bad and causing a direct continuous contact drain. If you replace the horn relay and the horn blows on contact then it is the ring. Very simple to replace with Wayne,s excellent book, and the part from Pelican was about 90 bucks. No more problems with the battery and my 97 has sat for over a week and started right up. Hope this helps.
fahmasan is offline   Reply With Quote
