I have a 99 base USA Spec. Changed my fluid when I replaced the waterlogged brake booster. While I was at it I replaced the master cylinder and installed the retro kit to eliminate said water logged brake booster. I just opened up the right rear bleeder valve and let gravity take its course. Thouroghly drained all fluid and replaced bleeder valves with speed bleeders from pelican. While I had the system drained I cleaned and painted my calipers and replaced rotors with drilled rotors.
99 Porsche Boxster
