Old 03-22-2016, 04:55 PM   #5
johnsjmc
The bearing is described as similar quality to the original single row bearing. A spacer is supplied if you are replacing a double row one. As said above I wouldn,t use it to replace a double row one but would consider it an acceptable replacement for a single row (but NOT an improvement like a ceramic one might be.) Whatever you do DO NOT USE PELICAN flawed installation instructions. Use the ones from LN.
johnsjmc is offline   Reply With Quote
