Old 03-20-2016, 07:32 AM   #4
Gilles
Then take the car out for a good 20 min. or so run, and don't turn it off when you get back, hook up the Durametric and test it then.
JFP,
My Durametric instructions state to first turn the flashers On, then to turn On the ignition switch...
But you are metioning that you can connect the cable to take the readings without turning the engine Off.
Most likely I don't know how to use it properly, let alone correctly understanding the readings... LOL
Gilles is offline   Reply With Quote
