Old 03-16-2016, 04:16 PM   #14
geraintthomas
geraintthomas's Avatar
Done!
Thanks to Particlewave for telling me which wires I had to tap into to get a feed that mimics the courtesy light, without running a wire up the a-pillars.
Behind the fusebox is this wiring loom, and behind this wiring loom there's a few wires coming through the door:
It's a very, very tight spot. So first of all I had to extend the wires, to make it easier to wire in footwell lights later:
Then I made the loom. I've got two warm-white SMD pads that mimic the amber colour of a halogen bulb:
And fitted!
They're brilliant. Perfectly authentic and they look completely genuine. The only fiddly bit was cutting the wires above the fusebox, and putting extensions of wire on them, only because there was literally no room to work and the wires were very short due to them being part of a very well wrapped loom.
I'll get on with installing the constant-on very dim amber SMD's soon.
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
