Old 03-16-2016, 08:49 AM   #18
JFP in PA
No oil required because the PTFE is already slippery enough to fit ?
But you will need the correct tool to successfully fit the new seal.There are accounts of people trying to tap it in with just a hammer and a drift - they often don't go well.
Over on RennTech 986 Boxster tech forum(Not Rennlist!)there are details for a home-made pvc pipe tool to set the seal to the correct depth and square to the cranckase/halves. If you don't have the Porsche tool , I suggest you at least need the home made one.
PTFE is self lubricating.
You can make a perfectly serviceable tool out of $4 CPVC pipe coupling and your old flywheel bolts that will install the seal correctly. This was written up here and on other sites more than once.
The biggest problem people encounter is that they do not research what they need to know about a project like this, and move ahead like a bull in a china shop, which can be a path to heartaches. Some shops even act this way; we had another shop blow the installation three times on one car before they called me. I went over and checked the case bore to make sure it was still round, and that it and the crank were clean and not damaged by all the attempts, and then installed a new seal in engine in about 10 min., and it only took that long because they kept asking questions as I did the install. That one worked perfectly.
The correct way to install this seal has been written up on multiple sites and in Excellence Magazine, so the information is out there.
