Old 03-16-2016, 01:14 AM   #7
JFP in PA
Besides using the ratcheting straps to pull it back into position, another trick is to mark the pan when you remove it and cut a 2 1/4 diameter hole under the drain plug. Once back in place, you will never need to remove the pan again to drain the gearbox.
