NO NO NO NO NO!!!!
do not use a metal impeller. Should the bearing start to fail it will grind your engine block
Get a Pierburg water pump who makes them for Porsche
They are under $200 from warehouse 33 auto . com. (Remove spaces) If you enter RENNLIST at the checkout you get a 10% discount as well.
While you are changing the wp, replace the thermostat with a low temp one
Get a new mechanic, one that actually knows about Porsche cars
2004 996 Targa Tip
Instructor - San Diego region
