Use gt3 water pump with metal impeller?
Okay indie says they typically replace Boxster water pumps with the metal impeller ones found on the gt3. I've seen some threads indicating that might not be advised due to possible block milling if the impeller gets a little loose. Thoughts?
2003 Boxster S
2004 Carrera Cab
