Old 03-13-2016, 06:43 AM   #12
jdraupp
Originally Posted by cornontherob View Post
Just crawled underneath the car, everything looks dry, save for road dirt and mud. Should I try adding a UV visible dye in the oil and then checking with a light?
No, that's not recommended. If you aren't seeing an oil leak and you're still convinced that this thing is using oil, then either get a nanometer to check the vacuum to see if your aos is suspect or just replace it if it hasnt been done.
Or...drive it like you stole it. Sounds to me like you're becoming a Porsche hypochondriac. Life is short. All engines will fail eventually. Just drive the thing.
