Old 03-11-2016, 05:55 PM   #6
husker boxster
husker boxster's Avatar
I would say the majority of the tighter feel is due to the bushings. The OEM bushings have an inner piece made of firm rubber but it supposedly wears / elongates as it ages. Has to cause the shifter of get sloppy over time. The OEM triangle piece is held in place by a plastic pin that probably also wears out over time. The Function-First triangle piece uses a metal pin which would reduce the chance of wear.
If you already have the bushings changed out, you probably have the majority of the fix.
1989 928 S4 5 spd - black
