			I would say the majority of the tighter feel is due to the bushings.  The OEM bushings have an inner piece made of firm rubber but it supposedly wears / elongates as it ages.  Has to cause the shifter of get sloppy over time.  The OEM triangle piece is held in place by a plastic pin that probably also wears out over time.  The Function-First triangle piece uses a metal pin which would reduce the chance of wear.
 If you already have the bushings changed out, you probably have the majority of the fix.
				__________________GPRPCA Chief Driving Instructor
 2008 Boxster S Limited Edition  #005
 1989 928 S4 5 spd - black
