Old 03-11-2016, 12:17 PM   #7
particlewave
Ger - no reason to run a wire all the way up to the dome light as there is a wire right at your feet that you can tap into.
Near the fusebox, the door harness enters the passenger cabin. You can tap into the door courtesy lights from there.
I'll see if I can find a pic and get you the wire color code.
