Old 03-10-2016, 09:45 PM   #25
oneshot
oneshot's Avatar
I've got the Pioneer fully wired up for usb out to near my center console and the microphone out the steering column for voice commands and hands free calls. I moved it to 'slot 3'. I took the cup holders out during the fun wiring part and reinstalled in slot 1 with the cd holder in slot 2. I've got a second usb for a possible iPad dash in the near future.
It should be noted the metra harness had the power lines wired backwards. I had to switch the pins for 12v switched and constant. The color coding was just wrong. Figured that out after setting the clock the third time....
Alarm went off randomly getting in at one point...
I thought all was well once I disconnected the known to be a problem radio alarm ground.
Then, somehow my 'brand new expensive keyfob' stopped working the keyless function. Had to perform the battery flip inside it trick from some TSB to regain control. I think I am back in control of my life now.
oneshot is offline   Reply With Quote
