Old 03-10-2016, 02:05 PM   #27
cole9900
Question for Dave and Chuck Re: window regulator fix
Facing the exact same issue. Both failed within one week of each other. Dave, since you had to drill to get the adjuster in place, I assume you had to disconnect the cable and move it out of the way. That would also allow you to remove the tip from the cable housing. Can you share how that is done?
Chuck, since it looks as if you did not have to drill, can you tell me how you got the adjuster in place? Was there enough slack in the cable to get it in place?
Thank for these tips. My mechanic wanted 1,200 to install two new OEM regulators!!!
cole9900 is offline   Reply With Quote
