Thread: 245/275
Old 03-06-2016, 01:58 PM   #15
LAP1DOUG
LAP1DOUG's Avatar
ps, if i were to try and squeeze 255/285s in there, what offsets would work? i currently am 1.5" lower w -1.5 front -1 rear camber. front wheels are 8.5" wide ET 53 and from what i can tell a 7 mm spacer should get me 245s, and somewhere in 10 to 15 mm will fit a 255. in the rear no idea; wheels are 10" wide ET 40.
and, not really related, if people are fitting 285 mm wide tires with no issue, and a 11" wheel is 280 mm wide, how come everyone on the internet says you can't fit 11" wheels? is it a coilover vs stock suspension thing? would certainly open up the range of wheels available if we could fit more 996 wheels.
I have run 255's on the OZ 8.5" et 53 wheels with 7 mm spacers, BUT my car has coilovers and adjustable caster. Without the adjustable caster, you will probably have heavy scrubbing of the wheel liners at anything over about 1 turn of the wheel. Without any spacers looks like it would work without scrubbing according to my calculations, but you may have trouble with clearance to the OEM strut. I can't help you with any data on that, as I have never run the OEM suspension.
I have never done any trials or calculations with 11" wheels on the rear. The general internet wisdom is that it doesn't work, but I think I saw one post where some guy said it worked with just the right offset and lots of negative camber.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
