Got the top speed test pipes installed! Exactly what I was after. Sounds great when you're on the throttle but stock volume otherwise. A subtle, but noticeable improvement overall. I wouldn't say it would be worth it at the price fabspeed charges for these pipes, but for what the top speed pipes costed it's a great value. A word of advice, the bolts included in the kit are garbage. All of them accepted 14mm nuts but 2 of the 6 didn't have 14mm heads. I ended up putting the stock bolts back into the welded top nut on the header flange and I plan to change out the rest of the top speed bolts at some point. I also had to cut about a 1/4-1/3" off the adapter piece on the passenger side to make it fit. Drivers side fit perfect, however. I'll try to take a vid if anyone else is considering this setup.
