Old 03-03-2016, 08:24 AM   #13
Dubaday
Dubaday's Avatar
Timely post. I bought the Motive a month back so I could do the brake bleed but I also wanted to do the Clutch fluid portion as well but heard bad things could happen trying to bleed clutch fluid.
So how is the process of doing brakes and Clutch at the same time.
Do all 4 corners then Clutch?
Then a quick recycle of 4 corners then Clutch?
Hey kk2002s,
I found a good write-up from pedro's garage that I will follow myself. Thanks pedro, for this detailed step by step instructions.
Bleed the Brakes and Clutch Porsche DIY
Good luck,
Randy
Dubaday is offline   Reply With Quote
