i dont know for sure but...
you should:
change oil & filter
airfilter
pollen filter
change spark plugs
bleed brakes
I think there is some poly rib thingy that gets replaced round that mileage. i could look this up, but i dont feel like it. its probably in my owners manual, but thats all the way in the garage.
Aw S$%# now i feel like an @#$#!!%!! Fine Ill go to the garage. Are you happy now?
Hold on
OK
poly rib should be replaced at 60k, did you do it?
at 90k you also need to change your manual transmission oil or if you have a tip,
change the ATF and ATF filter and also
change the oil in the differential
there! you made me get up! i hope your happy
