Old 03-02-2016, 11:49 AM   #13
Gilles
Originally Posted by tada View Post
Well, here's a small update, a chance for me to vent, and maybe some humor.
So the car will start every time, but it will not idle above 300 rpm (I guess the first tick on the tach), and it will die after a short time idling. Giving it any gas pedal will cause a little bit of rev (very little) and then stalling and dying.
Tada,
The symptoms you are describing reminds me of one time after re-installing the throttle body I was not able to maintain idle, and after a lot of head scratching I noticed that one of the small pins inside the connector that goes to the throttle body was bent...
After getting the single pin straight again, the engine ran smooth ever again .. :-)
It may not be your cause but simple enough to check, good luck!
