The passenger door lock (like the one I used in the link) has 3 microswitches built into it: door opened/closed, door locked/unlocked and safe contact. The door opened/closed microswitch affects the window drop function by causing your window to not drop or stay dropped or go up and down randomly. The only other microswitches in the door are attached to the door handles and they activate the window drop function, but only when the door opened/closed switch tells the CLU that the door is closed. The driver's door lock has an extra microswitch which lets the CLU know when they key is turned to the open/closed position. All the microswitches apart from the door handle ones come as part of the door lock.
Sent from my Hudl 2 using Tapatalk
