Old 03-01-2016, 08:08 AM   #18
mipstien
Side Porsche
you are putting too much thought into this. I doubt you can see much difference between 215 and 225 vs 205 from 10 feet.
If anything the wider tire will fill the wheel well a little bit more. Bear in mind you are looking at 5 or 10 mm difference on each side of the wheel. that is approx less than 1/4" to less than 1/2 in.
Same thing on any diameter difference, less than 1/2" if any
Go with 225 on the front, the car will handle better
How much more $ are 225 vs 215. Probably is not much and considering you will have the tirezs for a while......
Goodyears warranty is 1/2 mileage for staggered setup regardless of the size
I guess thats a good point. If people are telling me that the fronts are lasting a long time then I guess what is 50$ difference per tire on the front.
mipstien is offline   Reply With Quote
