Old 03-01-2016, 05:58 AM   #35
eomak
Put top back on today. Thing is.. i really like the look of the orginal boxster with it off now.And to me this top is looking a bit much. Something that is trying to look like something that is not.Ricer car? And having seconds thoughts about installing the GT wing but kinda to late to turn back now. The wing fits the orginal Boxster rear trunk lid just enough to work. But this tops trunk lid is inch shorter in width"half a inch on each side shorter in width" whichs gives it that larger gap between the rear fenders and trunk lid, if looking closely at it.Plus it sits a bit lower then orginal lid.It will install but some slight mods are going to have to take place. The GT wing is dam more heavier then i thought it would be. Its like almost 10lbs. and came with only 2 little dinky bolts on each side to screw in.Need to drill in larger holes to bolt in large bolts. Do not really want to start drilling holes yet. Maybe i can use 3M tape on it before i do the drilling to give a better look at it from all angle's.
eomak is online now   Reply With Quote
