02-29-2016, 10:38 PM
#1
Originally Posted by zehutiman
Ok, so I pored over all the connections and cleaned them, with no change.
I did discover something, however. As a very new Porsche owner, I remember threads about the ignition switch. After I start my Boxster, if I don't turn the key ever-so slightly to the right (1/4"?), things like the climate control don't work -- radio too, I think. When I tested the headlights, for some reason I didn't turn the key a bit further, like I usually do, and behold, neither low-beam on either headlight worked. But, when I moved the key just a bit to the right, the low-beam of the right headlight came on, but still no low-beam on the left.
Is this the source of my problems? Need a new ignition switch?
Replace the ignition switch! It's only $15 and you will eliminate lots of weird stuff!
