Old 02-29-2016, 06:46 PM   #2
jeeper31
jeeper31's Avatar
Originally Posted by Yellow986S View Post
You will require spacers for the rear to clear struts and caliper. Then you may have problems with rubbing the fender unless you have negative camber and roll the fenders. The fronts have a really high offset but should fit with a small spacer without problems
Thanks for response. What size spacers for front and rear. I have spacer in the rear. Not sure what size though.
jeeper31 is offline   Reply With Quote
