Old 02-29-2016, 06:40 PM   #1
Yellow986S
Yellow986S
Yellow986S's Avatar
You will require spacers for the rear to clear struts and caliper. Then you may have problems with rubbing the fender unless you have negative camber and roll the fenders. The fronts have a really high offset but should fit with a small spacer without problems
Yellow986S is offline   Reply With Quote
