Hake, et. al,
I contacted Rob from GAHH and he put me in touch with Jack, also at GAHH. Jack contacted my installer by phone (who he knew) and gave my installer some areas to check that could potentially be causing my problems.
While looking around my top my installer discovered a small pin that had broken or was just missing. I don't know how to describe the mechansim where the missing pin is suppose to be located, so I'm attaching a couple of pictures. One is from the passenger side and shows the pin in place. The other shows the missing pin. These areas are approximately to the left of your head if you are in the drivers seat and to the right of your head if you are sitting in the passenger side.
A few weeks ago I ordered the needed part, but unfortunately my parts guy ordered the wrong part. Just today I picked up the correct part. I will install it this weekend and hopefully find out if this was the problem, or not.
I will let you know the final outcome soon.
ddb
