The OEM water pump does use a plastic impeller. The clearance between the impeller and the block is pretty tight. If the bearing in the pump goes, which is often the mode of failure, the impeller scrapes the block. Metal impellers can carve through the passageway, rendering the case-half useless.
Rennzenn
Jfro@rennzenn.com
