Old 06-08-2006, 12:45 PM   #5
Brad Roberts
Brad Roberts's Avatar
Got it.
The early 986's have a issue with the line popping out of the power steering pump. I install a bracket that secures the line and keeps it from coming out (helps support the line)
I'm thinking about having a machine shop build a set of larger pulleys for the front of our engines. I need to slow down the accessories. The pumps are building too much pressure at Hi RPM for extended periods of time. Porsche figured this out on the GT3 engines. The lower pulley is a larger diameter then the 996/986/987/997 pulley's.
B
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
