One good thing about using tap water is you can forcibly flow lots of liquid through until it comes out completely clean, and do it in various directions from various inlets/outlets. There is just no way I can see that being done with gallon containers of water.
But then again, the area I live in gets water from a surface watershed (and not pumping it from underground wells/aquifers), so the water here has far fewer deposits than probably many other areas. Hard water deposits after washing don't seem to usually happen around here, and water heater descaling is also completely unnecessary to ever get done here, because there is just never any scale build up in the first place that needs removing.
2001 Boxster
