Old 02-22-2016, 11:00 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
The worst headlight ever. $25 ea
Update:
Only the driver side headlight is left. US shipping is going to cost around $20-$25.
It is in rough shape, but still good for practice de-ambering and HID install rehearsal.
So... buy a couple small interior trim pieces, electrical connectors, etc. from me and get the headlight free (+ shipping).
Original add:
I removed these from my 2000 (mostly) S and they are in bad shape.
I'll take $40 for the pair or $25 each plus actual shipping cost.
For shipping I have a 20"x20"x12" box they will both fit in at 15 lbs. I'll do FedEx, UPS, or USPS to US addresses. For really cheap individual shipping, I can wrap them in brown paper and tape a label on it. Canadians? I think you are out of luck on this one. Not worth the cost.
Free pick-up if you can ever catch me at home in northeast Ok.
Great for experimentation, lens removal, and de-amber practice. Probably not so good for use as actual headlights. Both actually worked before being removed from the car, but come with no guarantee.
Features...
Driver's side (left):
Looks dusty on the inside.
Has a damaged mounting bracket screwed to the bottom.
No back cover.
Missing turn signal socket.
Fog light cover missing and taped over.
Wiring wrapped in black tape.
A few minor cracks in the housing.
Corner piece has cracked lens and is glued on.
Lens is covered with a poorly done clear coat.
-SOLD-Passenger side (right):
No back cover.
Main lens is badly burned and just came completely loose as I picked it up.
Cracked insulation on wiring.
Peeling clear-coat on front surface.
Corner lens came off, but has a decent smoked surface (painted).
I still have the parts car and plenty of other odd parts that I should probably throw away. Feel free to PM me.
