Thread: brake bias
Old 02-20-2016, 12:00 PM   #1
The Radium King
The Radium King's Avatar
Originally Posted by jaykay View Post
TRK....any difference side to side? My front right would want to lock up ....likely due driver weight. Is there a safe side to side differential in pad compound that one can do?
I have completely melted front street tires at Shannoville (if you know it) presumably at a beginners pace; a very technical track. It seems be a common thing with the base set up of these cars. I did have a spaced rear track though. Tire pressures could have been high but wear indicators were showing good scrub
occasionally, but that i attribute to varying road surface. in your case i would consider a corner balance if possible?
