Thread: Buyer question
Old 02-19-2016, 08:56 PM   #16
tada
1998 Boxster Owner
Looks like in the video you have a slow blinking light on the temp gauge when it is running - Low coolant level. Just get some DISTILLED Water for now to top it off.
After you get it running well, I'd recommend a coolant flush and replace the water pump, unless you know it was done. I think replacement every 3-5 years is the recommended interval. (search it)
Check your coolant cap in the trunk for a leak. Make sure you have the new style cap. (search it)
Again, congrats!
Thanks! I'll work on the coolant level tomorrow. As for the stumbling, I'll start checking out the plugs and coil packs, and clean the MAF. And charge or replace the battery. It was unable to even turn over shortly after the video without a jump.
tada is offline   Reply With Quote
