Thread: Immobilizer
Old 02-19-2016, 07:35 AM   #2
ppbon
ppbon's Avatar
I'm a Scrutineer for PCA ...
… and we do allow for push-button start on SPB (Spec Boxster)
The rules state:
• ECU and programming must remain stock; no other engine management can be added.
• Steering wheel lock must be removed.
Most people remove the complete ignition lock (mechanical and electronic) - saves weight.
The Immobilizer wiring must remain intact, but you can attach the key's Immobilizer pill to the Immobilizer sensor therefore maintaining the ECU's functions intact.
You can then install a push-button start.
You also need to add an electrical kill switch.
Happy Boxstering,
Pedro
At the end of the day, its up the to sanctioning body to decide what is legal and what is illegal. Thus, the best course of action is not to make the call yourself, but to have the sanctioning body approve/disapprove the mod - then there won't be any issue if someone complains (and I can almost guarantee that someone, somewhere, at some time, will complain).
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
