					Originally Posted by Fatbloke  If it is only within a certain speed range and especially if your tyres are worn, it will be the balance. New tyres and/or a wheel balance should fix it. |
This is the key, if you feel it thru the steering wheel it's the front tire/wheel assembly. If you feel it thru the seat it's rear tire/wheel assembly.
Alignment has noting to do with vibrations.
				__________________OE engine rebuilt,3.6 litre LN Engineering billet sleeves,triple row IMSB,LN rods.  Deep sump oil pan with DT40 oil.
