Old 02-17-2016, 05:34 PM   #11
BYprodriver
BYprodriver's Avatar
Originally Posted by jaykay View Post
From the standpoint of straight mechanics I believe the larger diameter pistons give a greater potential for cylinder wall scuffing when coupled increased heat loads of the larger displacements. So you want to stroke it if you can......but in most cases that takes a much higher level of skill
Generally true about piston diameter, but longer stroke is problematic also. To minimize piston inertial cylinder loading you may need to increase connecting rod length. This also moves peak torque up the rpm range for higher horsepower peak.
I'm guessing Jake is building a shorter stroke, bigger bore engine to raise rpm level.
