That's exactly what I'm looking for! Is that adjuster intact with both screws rotating? I also see the attachment for the auto level motor. I attempted to pull the motor off but didn't want to pull too hard, doesn't seem right thing to do. As I pulled there seemed to be a white plastic lever that appeared to lock the ball into place. Detailed pictures of the adjuster mechanism and how it is assembled to the frame and the mount for the auto level socket connection would be much appreciated. Too bad it's not the other side if the adjustment mechanism is in good shape I would be interested in that piece, Although it would make a good cadaver to dissect. Thanks Kevin
