ABS dash light diagnosis...
So, today I replaced the rear rotors, pads and brake wear sensors on my 2000 Boxster 5-speed. I also washed out the engine compartment per some posts in this forum. No issues there. After completing all the brake work, bleeding brake lines, etc. I started the car. ABS light comes on. Trying to figure out what the problem is. Didn't touch any part of the ABS sensors during the brake work. Have read this could be as simple as a battery problem. Have already tested the brake pedal switch. I do have brake lights working, so that wouldn't appear to be the issue. Any thoughts from you guys?
