Old 06-07-2006, 08:58 PM   #14
986 in BC
Originally Posted by flyride
I also can't get the windows to go up, so I guess that would pose my 3rd question - will the windows go up if I can get the top up? Or am I looking at multiple problems? Or?
Flyride, I'm new to the forum as well, and to this problem.
In my research I've found several threads at Renntech.org that tells how to put the top in service mode. I believe it's also in the owner's manual, haven't checked it lately.
Once you have released the black and red (may be white) ball joints you should be able to move the top (Tool Pants explains it the best over at Renntech).
As for the windows, it could be a microswitch either at the top latch or on top of the top motor.
When the top is not latched and not in the full down position (you don't mention if the top light is still on) the windows will go down but will not go back up.
What I found works to check on a microswitch is to remove the top relay. This will bypass the latch microswitch and allow you to raise the windows. When you replace the relay, the windows should go down about 3". If you can't bring them back up again, then the microswitch that tells the relay that the top is fully down is not sending the right signal (either B pillar or motor microswitch).
(Search for microswitch or relay on Renntech) also use the microswitch trouble guide in this thread:
http://www.renntech.org/forums/index.php?showtopic=5208&hl=microswitch
986 in BC is offline   Reply With Quote
