Old 02-14-2016, 01:44 PM   #10
Topless
Track rat
Topless's Avatar
I wouldn't put 275/35 on the rear with 3.2L or smaller due to loss of torque multiplication.
285/30 is slightly shorter than 265/35 & works well as long as you use 10" wheel & there's no clearance problems.
275/35/17 actually works just fine on a Boxster if you are going for 245/275 stagger. The diameter is 24.7" so even a bit shorter than a 255/40/17.
http://www.tirerack.com/tires/tires.jsp?tireMake=Hoosier&tireModel=R7&partnum=735ZR7R7
